flint54 Posted October 3, 2012 Share Posted October 3, 2012 For AX15 transmission and for NP231 transfer case. Going to pull them, would like to pull them together. Anyone know these numbers? Thanks! Link to comment Share on other sites More sharing options...
mvusse Posted October 3, 2012 Share Posted October 3, 2012 Handled a number of transfer cases. Guessing about 50 pounds or so, possibly less. Don't know about the AX15. only had one vehicle with one and never had it out. Link to comment Share on other sites More sharing options...
MancheKid86 Posted October 3, 2012 Share Posted October 3, 2012 ax-15 is about 80-90 pounds tcase is 40, i installed both without a jack, did it in 2 parts Link to comment Share on other sites More sharing options...
ParadiseMJ Posted October 4, 2012 Share Posted October 4, 2012 ax-15 is about 80-90 pounds tcase is 40, i installed both without a jack, did it in 2 parts Unless you look like THIS... ...use a GOOD tranny or motorcycle jack. No need to bust a gut or kill yourself. Link to comment Share on other sites More sharing options...
flint54 Posted October 5, 2012 Author Share Posted October 5, 2012 I look better than that, and figured one hand to place it into position and the other hand to install the bolts. It's only aluminum for cryin' out loud. Link to comment Share on other sites More sharing options...
Geonovast Posted October 5, 2012 Share Posted October 5, 2012 The case is aluminum, and it's pretty thick... the insides are not aluminum... Link to comment Share on other sites More sharing options...
flint54 Posted October 7, 2012 Author Share Posted October 7, 2012 And the answer to my own question is: AX15 (with bell housing and clutch components) = 104 lb NP231 = 63 lb NP242 = 78 lb Separating the 231 from the AX15 in place was loads of fun, but handling them wasn't too bad. Nutserts have their own special place in hell. Had to cut the heads off of the T case bash plate center bolts. Link to comment Share on other sites More sharing options...
