mpace6a Posted October 1, 2012 Posted October 1, 2012 Just rebuild the carb for my 2.8, but before i put it in, i need to know if the gasket that goes between the carb and intake should be replaced or not. the gasket that was there had a small "grate" on the bottom of it with wiring coming off, and even has a square cut out on the intake for it to fit. the gasket in the kit does not have the grate on it. I'll try to get some pics of new vs old up, and top of the intake if needed, but hopefully someone can tell me without
jimoshel Posted October 1, 2012 Posted October 1, 2012 That's a EFE. It is not part of a carb rebuild kit. Clean it and put it back. Also called manifold heat thingy. It doesn't use gaskets.
