Eagle Posted September 23, 2012 Share Posted September 23, 2012 If anyone is cruising the pick-n-pull junkyards, please be on the lookout for a 97+ Cherokee with a factory gas tank skid. My wife's and my 2000 XJs both have the Up Country package, but I recently picked up a (somewhat) low mileage 2001 for our daughter, and I'd like to Up Country-ize it. I have the springs, I have a transfer case skid, and I think I have a front skid. I need a gas tank skid. TIA Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 23, 2012 Share Posted September 23, 2012 Once you find the tank skid you'll probably have to install nutserts in the frame holes to install it Eagle. I had to. PITA........ Link to comment Share on other sites More sharing options...
Eagle Posted September 23, 2012 Author Share Posted September 23, 2012 Once you find the tank skid you'll probably have to install nutserts in the frame holes to install it Eagle. I had to. PITA........ Correct. The right side should be there, used for the tailpipe hanger. I have a set of new hitch nut plates for the XJ that I'll use if needed. Link to comment Share on other sites More sharing options...
jimoshel Posted September 23, 2012 Share Posted September 23, 2012 If you can't find one closer to home, I believe I've got one. Also got the front skid. Link to comment Share on other sites More sharing options...
