89MJComanche Posted September 10, 2012 Share Posted September 10, 2012 Found a perfect 96 4 cyl Xj donor to make our 88 2.5 into a 4x4. What do I need to verify? Spline counts? Anything? Guy wants $300 for tranny/tcase Link to comment Share on other sites More sharing options...
1989 Eliminator Posted September 10, 2012 Share Posted September 10, 2012 I have all that you will need at home (I'm at work) ill send you all the info later. :cheers: Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 11, 2012 Share Posted September 11, 2012 You need linkage. Master and slave. Front axle.....with brakes. Front drive shaft. Grab the boot and shifter knob.......4x4 indicator at handle........grab the console. I'd rather have the whole XJ........offer him $500..........scrap it for $400. Save the extra bolts.....goodies.......starter..........alt.......etc.... You'll need to have a new rear drive shaft made.......no you won't find one.........no the XJ won't work.........yes 3" diameter.........no your old 2 piece (shaft in shaft) ain't worth having. Grab the metal valve cover. Radiator. Confirm your dif ratio..........XJ should have a 4.10 D30 and your D35 should be a 4.11 Link to comment Share on other sites More sharing options...
