on my comanche i was wondering if i can just take that rear proportioning valve over the rear end off. if not can someone give me a picture of the stock location that the lever is sopose to be in.
what I did on mine was unscrew the brake line from the rear valve and screw it into the other line going to the rear splitter then I clipped and crushed the return line since my lines are mostly frozen in place.
After hauling my uncle's fire proof gun safe down to our ranch my rear load sensing valve decided to pretend it was still loaded leading to incredible brake performance. So my dad just disconnected the rod and pushed it up a bit for now. no problems and that was back in december.
In the future we will eliminate completely as this truck is not really intended for hauling 700 lb loads.
