I need the wiring harness that goes to the fuel injectors or maybe the whole under hood harness. The field mice has reaked havok under the hood.I have a 90 model mj with a renix 4.0. Thanks in advance
sorry man, tried pulling it without having to cut it, but after closer inspection I wouldnt of sold it to you per its condition. I though all my issues was from my fuse block but I was wrong, found some major splicing and chaffing in the wires.
I need all the injector harness and if you would cut just the plugs to the other sensors and leave about 2 or 3 inches for a pig tail so I caaba put them on my harness. Thanks
Guess you still need this, what's your offer on it? I have no idea what it's worth and want to know if it'd be worth the pain of removing from the parts truck (which is a 90 4.0 auto).
I really don't know what it would be worth, if you would cut the plugs back 4 or 5 inches so i could solder them i could make it work and it may be easier than removing the whole harness. Let me know I'm sure we can work something out.
