90 Grand Wagoneer NW,IL
whowey
I really hate giving up the most fun on the street Jeep I have ever owned. But unfortunately it doesn't fit my lifestyle anymore.
90 GW
AMC 360
TC727 tranny
Select-Trac transfer case
Dana 44 front and rear axles with a 2.72 ratio
Less than 100k miles on it, but it is being driven daily right now and its close to passing 100k.
The body and interior are good enough that this Waggy doesn't deserved parted out. But.... the frame has coffin rot and another couple spots of rust through. The rear window motor does not work and its disconnected. The stock carb needs rebuilt, and causes some typical running/starting issues. The interior headliner is toast. This Jeep has had the CS-130 alternator conversion done.
My stash of Waggy parts comes with the Jeep. It includes:
2 Razor grills with headlight buckets
Final edition Grill
Complete TFI set-up including plugs
Factory Class 2 trailer hitch
Same colored Front Fenders
The cargo cover for the cargo area
Working rear window motor
Carb rebuild kit including power valve
Mostly complete working emissions system
Bin of misc hoses and tubes I removed as I replaced vacuum hoses.
Here are pics of it. I will add more if there are specific requests.
$3000 or offer.
Archived
