1992 Cherokee Laredo, $150, Located in Maryland
combatcamera
For Sale:
$150.00 (yes, $150.00, there isn’t a missing zero)
1992 Jeep Cherokee Laredo
252,000 miles
automatic
Power windows, power locks, air conditioning
Aftermarket stereo
Has Reese receiver hitch
No rust issues, has a few small areas of rust, but nothing that couldn’t be fixed with sandpaper.
Most body panels straight
Comes with Nates 4x4 offroad front bumper
Engine has no known issues, runs strong when started
Bad parts (and reason for the price)
Drivers side door needs to be replaced, or, really, needs new hinges. Pins are bent on the hinge part on the door. Door does not latch or stay on the vehicle when opened. Speaker wires and power for window motors/ locks have been cut. They can easily be spliced, however.
Dashboard trim has been taken off and dash is partially disassembled. All parts are there, just need to be put back on.
Engine does not start. The engine should run, and run strong, however, somebody broke into the truck and tried to steal it. There is damage to the steering column and to the ignition. Key turns in ignition, but nothing happens.
The damage to the steering column also has affected the steering. Steering wheel turns, but the front wheels do not. Front wheels do turn how they should when truck is towed.
Missing the front fender flares and the bezels/ trim pieces around the headlights.
Driver’s side taillight is broken, cracked etc..
Clean and clear title in my name. Truck is located in Greenbelt, Md., near Washington, D.C.
Archived
