HOrnbrod Posted February 20, 2013 Share Posted February 20, 2013 I've never had a vehicle with that much difference in caster shimming between the left and right sides. I think you should p/u an angle finder and measure caster on both sides to see what you have. Angle finders can be had anywhere, like here: http://www.lowes.com/pd_198122-1099-AF006M_0__?Ntt=angle+finder&UserSearch=angle+finder&productId=1057041&rpp=32 Once you measure, then we can commence with proper shimming. I don't have much faith in the idiot you originally brought your truck in for alignment. Link to comment Share on other sites More sharing options...
87Chief Posted February 20, 2013 Author Share Posted February 20, 2013 I will pick up an angle finder tomorrow and get on it! Thanks again! Link to comment Share on other sites More sharing options...
87Chief Posted February 21, 2013 Author Share Posted February 21, 2013 Got some measurements... Link to comment Share on other sites More sharing options...
Eagle Posted February 21, 2013 Share Posted February 21, 2013 Never mind the drive shaft for now. You need to park the Jeep on a LEVEL floor and measure the angle on the tops of the upper ball joints on both sides of the axle. That's your caster angle. Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 21, 2013 Share Posted February 21, 2013 Kind of like this. Use the top flat of the upper ball joint. Use a socket if the zerk fitting gets in the way. Link to comment Share on other sites More sharing options...
87Chief Posted February 21, 2013 Author Share Posted February 21, 2013 Ok, will do. Link to comment Share on other sites More sharing options...
87Chief Posted February 21, 2013 Author Share Posted February 21, 2013 Driver's side... How I did it to make sure it's right.. Passenger: Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 21, 2013 Share Posted February 21, 2013 You have about 6* on the passenger's side (because of all the shims) and 3* on the drivers. Now shim both sides the same to get the angles as close to being equal as possible. You should get around 4*-5* on each side. EDIT: Are you on level ground? Link to comment Share on other sites More sharing options...
87Chief Posted February 21, 2013 Author Share Posted February 21, 2013 Even though the alignment sheet (on page 2) says they are both at ~3*? I'm not trying to prove you wrong at all or anything, I just want to get it right.. Also if my truck is wandering all over the road it would be caster causing that correcT? One more thing.. I'm driving, and I make a left turn at about 10 mph, feels like my truck is going to roll over on its side, but it doesn't do it as much on the right.. Caster causing that too? Thanks for the help so far, it's great getting this kind of help! EDIT: Yes, I am on level ground in the garage. Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 21, 2013 Share Posted February 21, 2013 Obviously, if you made the measurements correctly, you have unequal caster R&L. These measurements assume that you are on level ground and your ball joints are in good shape. If mine, I would jack each wheel off the ground, put a 2x4 under each wheel, lift the wheel up and down vertically and check for play in the ball joints. It's good to have a helper for this. If no play, I'd shim out both LCAs equally then re-measure. Link to comment Share on other sites More sharing options...
87Chief Posted February 21, 2013 Author Share Posted February 21, 2013 Ok. Awesome. Thanks for the help hornbrod! Link to comment Share on other sites More sharing options...
