rollovercomancheguy Posted July 29, 2012 Posted July 29, 2012 Here it goes ive got it pinpointed to the front dana 30 . It sounds like the fan is hitting something i did away with the vac disconnect by installing a one piece xj shaft, and removed th fork.I know it nothing brake related no marks on rotors or unevenly worn pads any ideas?
mountainman Posted July 29, 2012 Posted July 29, 2012 Prob bad wheel bearing. jack up the front and spin the wheels and listen. Also grab each wheel top and bottom and wiggle. See if you have any play. That will show you which one is toasty. But usually you will hear the nois when you spin the offending side. :)
rollovercomancheguy Posted July 30, 2012 Author Posted July 30, 2012 Sweet ill try that tomm thanks for the idea :USAflag:
