bigredjeep1 Posted July 23, 2012 Posted July 23, 2012 http://chicago.craigslist.org/nwc/cto/3134884934.html $800 for 35x12.5x15 new Pro Comp MT tires on 5 on 5.5 rims Nice dana full width dana HP44 & Ford 9" axles with ford radius/Ruff Stuff heavy duty long arms with heim end (3 link long arm)...will include the frame end bracket mount so you can weld them up and bolt into a MJ....or a XJ with a little work (rear spring perches are different then XJ I hear) but same SOA setup. $1300 FIRM on the pair of axles with stock HP44 steering, long arms, Ruff Stuff double adj track bar ($270 new), also newer 6" Rubicon Express coil springs & rear MJ springs with add a leaf....so this is a plug and play upgrade for someone. Dana HP44 front axle with 4.10 gears and lincoln locked and newer Warn hubs Ford 9" rear axle with 4.10 gears and limited slip and drum brakes both 5 on 5.5 Selling whole truck or parts but scrapping soon so please let me know what parts I can pull for you from the 87' MJ, I will not pull drivetrain other then the axles and driveshafts. Maybe the t-case. LOL Troy 815 222 nine four 0 nine troystein@gmail.com Located in Roscoe, IL 61073
bigredjeep1 Posted July 24, 2012 Author Posted July 24, 2012 $1200 for the entire MJ !!! $1800 with 35" PC MTs on it I pirated both bumpers and engine cooling system off of it. :brows: 815 222 nine four 0 nine and/or troystein@gmail.com
Automan2164 Posted July 24, 2012 Posted July 24, 2012 Let me know if you get down to the interior... I've had a couple members asking if I might pull it for them. Rob :cheers:
bigredjeep1 Posted July 30, 2012 Author Posted July 30, 2012 I'm trying to sell it whole ($1200), but if I don't in the next few weeks I will part it out and do my best to grab anything of value before it goes to the scraper.
88SGTSlaughter Posted July 31, 2012 Posted July 31, 2012 Is everything still there? Axles, suspension? And hows is the motor and trans?
bigredjeep1 Posted July 31, 2012 Author Posted July 31, 2012 Motor was using a quart of oil a week before Jeep broke down on me on the road. Tranny worked ok but motor and tranny 92' so tranny had to be manually shifted with Renix electronics. I pirated bumpers, radiator, 35" tires, and nose of the Jeep otherwise it is still there with roller tires on it now. $1200 takes the whole MJ with beefy long arms, track bar, 6" RE coils, dana hp44/9" with 4.10 gears and locked f/r. SOA in the back with a add a leaf for 8" lift on the MJ.
88SGTSlaughter Posted July 31, 2012 Posted July 31, 2012 Thanks, I have a few things pendin sale, 35"s, d60's and other misc. if it goes quick I'll see what I can do.
bigredjeep1 Posted August 1, 2012 Author Posted August 1, 2012 I don't want to scrap this MJ minus the axles/suspension/interior but I can't have it sitting around alot longer not running. I have 6 Jeeps and a baby on the way and need to sell some stuff. $1200 for the whole MJ is a fair price I feel, am I wrong? :nuts:
86customanche Posted August 2, 2012 Posted August 2, 2012 1200 is a very fair price. the suspension/axles is worth that itself. unfortunately, i am only looking for the front axle and long arms...and i live very far away.
tazer15 Posted August 4, 2012 Posted August 4, 2012 Id be intrested in front springs and trackbar maybe long arms too if you part
Archived
