Passenger Side E brake cable
mj2stay
86' comanche, long wheel base. I need the cable that runs from the e brake split-bracket to the drum brake housing on the passenger side. At this time, I only have the drivers side e brake hooked up. I dsconnected the passenger side cable from the lever inside the drum housing. Does anyone think this is a bad idea?
The rear cable from the split to drum is the same for both sides. Not sure about some auto parts stores but it shows that Oreilly auto has the cable available part number BC93591. When I was doing the brake system on the manche I bought 2 of them and they fit perfectly.
