jimoshel Posted July 17, 2012 Share Posted July 17, 2012 There's a dearth of information here on swapping a Renix 4.0 out for a HO 4.0. There is nothing on swapping 2.5's. Or maybe I just couldn't find it. I have a '94XJ with a 2.5, AX15, I'm going to swap into a '87MJ, AX4, also a 2.5. I'm planning on setting the 2 engines side by side and trading anything that looks different between them. The XJ is 4WD and the MJ is 2WD which is why I'm not swapping trannys also. Surely this has been done B4. Anyone got any links or tips on this? TNX, Jim Link to comment Share on other sites More sharing options...
Geonovast Posted July 17, 2012 Share Posted July 17, 2012 2.5's a 2.5. Just make sure you keep the Renix manifolds, flywheel, dizzy and sensors, and you'll be fine. Link to comment Share on other sites More sharing options...
