Anyone swap out the hi low wiper stalk/module for the nicer one? I have a 93 XJ to harvest parts from, not sure how interchangeable some of this stuff is. If so what stuff needs to be transferred over? Thanks in advance
If your truck came w. non-delay wipers you will need to change out the multifunction switch/harness inside the column as delay wipers require one more contact/wire through delay box. The harness is included with a new multifunction switch. Be advised the MF switches for tilt and non-tilt columns are different. Changing the MF switch requires going deep into the steering column. You will also need to install the delay wiper module inline with the new harness and a new stalk with delay wiper function.
