so, i bought a new u-joint, given that the last one i bought blew up while installing it
and i got the new one all the way in, before realizing that it had no place for clips to go.... ?
i've now realized it is a driveshaft u-joint that just happens to come up because its the same exact size. it fits perfectly, but i can't clip it (outside style clips)
is there any harm in not clipping it?
(is there any harm in shooting the autozone people?)
well, success!
called the guy i worked with there earlier, and then went up there and exchanged for the correct part, 5$ cheaper :brows:, came home, and 30 min later i have a complete pass. axle-shaft assembly that spins about like butter. jamminz.gifjamminz.gifjamminz.gif
all in all MUCH better u-jiont experience than last time (for those of you that remember my pilsbury 'womp' biscuit u-jiont cap explosion last time i attempted to change one :roll: )
I know what you mean.. Pulled the front axle on my Ranger to replace the axle joints. Went to Auto Zone and picked up 2 new joints and a press to press the old ones out. Got the old ones out and pressed a new one in and then could not get the clips on. Checked the new one with a old one and everything is the same size except the clip slot is off by 3mm :mad:
Charles
I am very glad it finally went you way!!!
GOOD LOB!! :cheers:
CW
thanks man! it honestly was about 5000x easier than the last times i've dealt with them, don't know what the difference was? but i even took an origional spicer out of the stub i used, only took about 10 good hits with a 22oz ballpeen.
check out my wheelin pics at LAST!
I feel your pain. I rebuilt my front driveshaft today, and replaced the OTHER u joint in the rear.
I've replaced every u-joint on the MJ in the last 3 months.
