Guest Posted June 25, 2012 Posted June 25, 2012 I'm selling my 88 Comanche Metric ton, long bed, 4wd with meyer plow, 4.0, 5 speed (AX-15), D-30 CAD front and D-44 rear 3.07 gears, has 4.5" RE coils in front with BDS shocks, sprung over in the rear with ford explorer springs and coil over shocks. The plow has been lowered so it plows at the correct angle with the lift. Has the late model open cooling system. I have(6) wheels. one complete set of (4)30x9.50 15 toyo a/t tires on the turbine wheels and (2) 30x9.50 Toyo A/T's on steel wheels with tire chains mounted to them, seen in pic's. Hella 500 backup lights mounted in bumper. The parking brake needs some work missing the front cable ( I have the cable ) and the passenger floor will need some work soon. The t-case shifter linkage is not correct for the AX-15 so it doesn't shift properly. Interior could use some work as well. I have a bunch of parts to go with it. I do have the Grill, it was removed to run the plow wires and never put back on. The Comanche needs some TLC but is a good solid platform. $2800 OBO
landlubber Posted June 25, 2012 Posted June 25, 2012 why are you selling it? does it need much more besides interior and the minor things mentioned?
combatcamera Posted June 25, 2012 Posted June 25, 2012 Hi, Nice truck. I sent you a private message about it.
64 Cheyenne Posted July 31, 2012 Posted July 31, 2012 if I was closer I'd buy it for the plow then sell the truck.... :yes:
Archived
