my86manche Posted June 25, 2012 Posted June 25, 2012 my jeep has flares but id like an extra set and just other odds and ends of stuff but let me know but it really needs a new cab bad it has no floor pans its pretty much some fred flintstone stuff going on but the carpet keeps my feet from falling out lol and the box needs work but i can fix that
skidoo_j Posted June 25, 2012 Posted June 25, 2012 regarding the cab of the truck... If it's bad enough that you can't weld in new pans, or scrap steel you've gotta find a new truck. The front half of a comanche is a unibody. That means the cab is part of the structural frame. New floor pans are available for each side, or you can go to a junk yard and take a few cut off wheels with a grider and cut the floor pan out of an XJ some pounding is required for a perfect fit, but not as bad as scrap steel. Untill then yabadabba doo!!!
