Garage cleaning - NJ
mjtjnj
Used hub bearing for 87-89 $5
Clutch master cylinder $10
Pair of doors - Fits 4door Cherokee XJ and Comanche - non power, chrome handles - $100/set
Rear shackles (stock) for YJ Wrangler - $5
Pair of hardly used Dana 35 Drums - fits Wrangler, Cherokee, Comanche - $30/pair
Dana 35 chrome cover - good shape - $10
Dana 35 drum brake hardware, complete, and pads - fits Wrangler, Cherokee, Comanche - $10
Tail light lens - Wrangler - $5
Front brake hose (rubber) - Wrangler - $5
Sway bar end link - Wrangler - $5
Sway bar end link - from TJ - $5
Power steering box (gear) - fits Wrangler, Cherokee, Comanche, and Dodge Dakota - $15
2.5L throttle body - fits Wrangler, Cherokee, Comanche - $10
Somerville 08876.
Also have:
2 speedometer gears, long style, 35 and 40 teeth, $10 each
NP 231 transfer case, 21 spline, $100
electronic speedo sensor from np231, came off Wrangler, early 90s.
also have
front XJ/MJ license plate bracket - $5
multiple sending units - $5
4 cylinder full gauge cluster with tach, out of an 87MJ....197K on the clock, works fine - $100
  • 3 weeks later...
  • 1 month later...
Archived
