MCF90 Posted June 8, 2012 Posted June 8, 2012 Hey guys, how is the dash clock illuminated? Is there a bulb behind there? My clock seems to be working, but I can't read it unless I look at it at just the right angle and with just the right amont of ambient light. Thanks guys! Matt
mvusse Posted June 8, 2012 Posted June 8, 2012 Depends on the year. Some are a back lit LCD with a regular bulb behind the display, some use an LED display that is self lit. From your description I believe you have one with a bulb and the bulb has burned out. Quite simple to replace, just remove the dash bezel, then unscrew the clock.
Bhfear Posted June 9, 2012 Posted June 9, 2012 http://gojeep.willyshotrod.com/HowtoDashClock.htm seems to have tons of info on there
MCF90 Posted June 9, 2012 Author Posted June 9, 2012 Cool, thanks guys. I guess I should have specified, I have a 90 Comanche. Matt
MCF90 Posted June 10, 2012 Author Posted June 10, 2012 Well, I replaced the bulb, still no clock. I think it may be done. Matt
