Truckcom Posted June 4, 2012 Posted June 4, 2012 I have a parts comanche I keep across the street which, until now, has been driveable but apparently someone recently siphoned the fuel tank dry. When I went to start it, after a few attempts, I noticed no sound from the pump and checked to find no fuel at the rail. When I realized what had happened, I put 5 gallons of gas in the critter but still the pump is not running. The pump circuit is energized as far as the connection to the pump at the tank. I am guessing the pump may be stuck or damaged from running dry. Any quick fix suggestions?
HOrnbrod Posted June 4, 2012 Posted June 4, 2012 The pump grounds to a stud behind the left tail lamp. Make sure the ground is clean and tight there then check for continuity between it and the fuel pump connector at the tank.
