TTREB4 Posted May 24, 2012 Share Posted May 24, 2012 I picked up an 87 comanche 2WD with an inline 6 motor. Its been sitting for several years. It doesn't have a transmission. I need to pick up a manual transmission for this truck. Is there a difference between years of transmissions? I found a used one from an 89 comanche. Will this one work? Link to comment Share on other sites More sharing options...
MJRemi Posted May 24, 2012 Share Posted May 24, 2012 The 87 had the Peugeot BA/10 transmission and the 89 had that or the AX15 transmission. It's pretty much a bolt in but you need the transmission mount and crossmember if it's AX15. Link to comment Share on other sites More sharing options...
Rymanrph Posted May 24, 2012 Share Posted May 24, 2012 Where are you? I have an AX-15 I could hook you up with. Link to comment Share on other sites More sharing options...
TTREB4 Posted May 24, 2012 Author Share Posted May 24, 2012 The 87 had the Peugeot BA/10 transmission and the 89 had that or the AX15 transmission. It's pretty much a bolt in but you need the transmission mount and crossmember if it's AX15. Thanks. Is there anything else I need? How do you tell the two apart? Where are you? I have an AX-15 I could hook you up with. I live in Utah. I Hope that would be close. Link to comment Share on other sites More sharing options...
Rymanrph Posted May 24, 2012 Share Posted May 24, 2012 The 87 had the Peugeot BA/10 transmission and the 89 had that or the AX15 transmission. It's pretty much a bolt in but you need the transmission mount and crossmember if it's AX15. Thanks. Is there anything else I need? How do you tell the two apart? The Puegeot is split down the middle. They were in trucks until about mid '89 I believe I live in Utah. I Hope that would be close. Only if you consider 2,000 miles close... Link to comment Share on other sites More sharing options...
