RockMJ Posted April 30, 2012 Share Posted April 30, 2012 Hey guys, I'm getting some smaller things done on the MJ after all the paint and bodywork and since I never listen to the radio and I'm putting a Cobra weatherband CB in instead I had an idea. With the newer 97+ front end swap the old radio antenna won't work for me anyways so has anyone put a CB antenna in the radio antenna's place? I was thinking of fabing up a bracket to bolt to the inner fender and have the CB antenna poke up through the fender and put a gasket of some sort in the fender hole to protect the paint and keep the antenna somewhat rigid to that point. I plan to reuse the radio antenna grommet into the cab and just seal it with RTV where I cut it. Thoughts on this? Pics of it having been done? RockMJ Link to comment Share on other sites More sharing options...
mvusse Posted April 30, 2012 Share Posted April 30, 2012 I had done this in the past, and couldn't get the SWR down below 2.3. Tried with a 4" fiberglass whip from Radio Shack, 3' Firestick and 3' K40. With a 102" whip I got 1.7. The fender is just not a good place for a CB antenna. I now run the 3' K40 on top of a spring mount on the middle of the roof with an SWR of 1.0. Link to comment Share on other sites More sharing options...
