comanche club Forum Software. We need some input.
I finally successfully removed your admin status as per requested. :thumbsup: the number of spammers has actually gone up. I used to leave them in the database because they can't try the same name of email twice. but after you mentioned they were eating our space, I purged them all. :typing:
probably. if someone could explain in english what I need to do. :dunce: I'm guessing he needs my password to get to the cPanel?
also, we should probably arrange this with our hosts so that they can be sure to make a backup copy just before he starts tinkering.
Just a tip. I do not know if your version of the phpbb supports it, but on local swedish forum i added a normal question, to which you had to type in the answer. This should remove any spambots. As per the human ones, we don't have that problem since the question I added was in swedish. Seems most human spammers arent swedish :)
That won't help you though, since english is a tad more common
Cheers
Lord Whistleton
