speedo gears
that is a good question... that i don't have an answer for..
but i would put the long shaft gear and try the different positions to see if the teeth will mesh properly, can't hurt too much to try right?
edit, if you can swap the gear it self then that may be the way to go if the first try with the old one does not work. would need to find a way to keep the gear from free spinning on the shaft
