Comanche1987 Posted April 10, 2012 Share Posted April 10, 2012 Recently my waterpump bearing gave out causing the pump to leak. I replaced the pump last night (after work and really tired). I got "integral serpentene belt that looked similar to my dieing pump from the front. I replaced the lower hose and the thermostat (o.e. temp) as well. The heater valve broke so I bypassed it, the coolant system was filled with nasty rusty water, i flushed it the best I could with fresh water. I tried to bleed the cooling system but it seemed like the thermostat wasn't opening. I removed the thermostat and tried it again, it would very slowly overheat still. The cooling system worked fine before so I am doubting a clogged radiator but its possible, a friend subjested a reverse flow water pump was given to me. Any thoughts? I'll try to get some pictures. I can drive about 4 miles before having to pull over and let it cool down (gets to about 210-220). Link to comment Share on other sites More sharing options...
Comanche1987 Posted April 10, 2012 Author Share Posted April 10, 2012 pump I bought http://www.oreillyauto.com/site/c/detai ... &ppt=C0331 Master Pro Reman Water Pump - Water Pump $20.99 Each Plus Core - $1.00 Add to Printable List Online: Available Call Store: Usually Avail. 24 Hrs Find store with item 1 year limited warranty •Remanufactured •With Serpentine Belt •With Integral Pipe Link to comment Share on other sites More sharing options...
Comanche1987 Posted April 10, 2012 Author Share Posted April 10, 2012 my old pump Link to comment Share on other sites More sharing options...
Comanche1987 Posted April 10, 2012 Author Share Posted April 10, 2012 any advice? about to get off work and start figuring out the puzzle. Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 11, 2012 Share Posted April 11, 2012 Did you compare the two before you put the new one on? Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 11, 2012 Share Posted April 11, 2012 BTW your friend is correct.........they come in both rotations. Link to comment Share on other sites More sharing options...
Comanche1987 Posted April 11, 2012 Author Share Posted April 11, 2012 ... clogged radiator? Link to comment Share on other sites More sharing options...
