Ranch Manche
Well I better start a re-build thread on the newest member to our fleet, I name it the "Ranche Manche" as it's sat in a field since 2005. So here we go, first goal make it run
$25.00 in fuel and fresh oil and a trust flat screwdriver as the column is all bound up.
Well here is what we have so far,..
In good company :)
Floors
Had some Mice! hope the carpet is salvageable,..
Temporary IGN Key,...
Interior
Part time light is stuck on,...
and I found the clutch is dead,... no pedal at all, I need to investigate to see it's internal slave or external
Fill the mc if empty and pump the clutch, if your foot gets wet its the master, if your tranny leaks its slave
Well I tinkered on the Ranch Manche today,.. checked cold start (AOK!) swapped on a good Tail gate that opened so I could toss a Chrysler 8.25 and D30 into the bed from the 88 DD and my neighbor and I were playing with the clutch pedal. With the cap on you could hear air loss, so he pulled the cap and a few bubbles came out of the reservoir,.. Now we have some pedal pressure but it escapes,... the pedal is low as well, but I did manage to move forward and backward a few times (WHOOT). So it may be air in the line or it there is a leak somewhere, but no visible leaks so far,..
Oh and no power to the A/C or heater motor,... turn the knob and nothing; nada; zilch,.. another day,..
and the E-brake and part time light are stuck on,.. again ,... another day
