Ok guys i need a quick answer. My mj when i got it had the load sensing valve arm pointed towards the tire with the rod almost parallel to the ground. Is it supposed to be pointing towards the diff with the rod perpendicular to the ground? Are all years the same? I know mine works cuz yesterday i had 1200lbs in the bed and i finally had rear brakes lol so for now i wanna keep it
Hey Don, what do you have going on for exhaust there?
:hijack:
Mine is getting really crusty looking after all the winters so I'm planning on having to redo it once it springs a leak somewhere. I have been thinking about what I want but would love to see some ideas and actual successfully completed routings. My Camaro has a two-out-the-left system and I was thinking it'd be cool for the MJ to have 2OTR to match, but due to cost will probably just wind up with a slash-cut stainless single pipe, mild muffler (Dynomax superturbo?) and stainless mandrel bends all the way up to the header all in stock diameter (2-1/4?).
