MancheKid86 Posted March 16, 2012 Share Posted March 16, 2012 road block, can't get tranny in, mounts are different on my 1999 ax-15, brings x-member 3 inches away from mounting location Link to comment Share on other sites More sharing options...
Abyx Posted March 16, 2012 Share Posted March 16, 2012 The mounts are completely different because there's actually two mounting locations on the frame rails; one that's located further forward(Puegot trans), and one that's located about 3" back for the AW4/AX15 trans. Odds are your weld nuts are rotted out in the frame too...hope you have access to a welder. This happened to me at 11pm at night trying to get my truck out of my friends' garage...luckily I had two weld nuts and my welder with me, though. Link to comment Share on other sites More sharing options...
mvusse Posted March 16, 2012 Share Posted March 16, 2012 The AX4/AX5 also uses the front locations. I swapped a 4wd AW4 into a 96 XJ in place of it's 2wd AW4 and I reused the mount. Your swapping in an AX15, but what are you swapping out? Link to comment Share on other sites More sharing options...
MancheKid86 Posted March 16, 2012 Author Share Posted March 16, 2012 didnt notice the other mounts, answers my question :shake: and not to sure :P havent bothered to check since its coming out Link to comment Share on other sites More sharing options...
