Shane Posted March 2, 2012 Share Posted March 2, 2012 I found some 2 inch coil spring spacers for 84-01 XJ. They will fit on my 89 MJ, correct? My truck has the rake to it. I was doin this 2 inch up front and maybe a 1 inch lift shackle in the rear (as this is my DD and will seldom be taken offroad). This should level it out, right? Or should I leave the rear alone? I wanted a little lift but on a budget. Link to comment Share on other sites More sharing options...
FrankTheDog Posted March 2, 2012 Share Posted March 2, 2012 Put the spacers in front, drive it around some and see how it sits. If you feel it then needs the shackles, put them in. Link to comment Share on other sites More sharing options...
Pete M Posted March 2, 2012 Share Posted March 2, 2012 I agree. don't forget to check you alignment after the pucks. :thumbsup: Link to comment Share on other sites More sharing options...
Shane Posted March 2, 2012 Author Share Posted March 2, 2012 Thanks guys. I figured it would work, but when you hear something different you might as well double check, right? Link to comment Share on other sites More sharing options...
