Blue88Comanche Posted February 28, 2012 Share Posted February 28, 2012 As the title says, how does one gravity bleed a clutch? Link to comment Share on other sites More sharing options...
Eagle Posted February 28, 2012 Share Posted February 28, 2012 To gravity bleed, you open the bleeder and leave the cap on the reservoir loose so air can get in. It's a PITA doing brakes that way. I'm 99.837 percent certain it won't work for the clutch. Link to comment Share on other sites More sharing options...
kyleag89 Posted February 28, 2012 Share Posted February 28, 2012 When I just replaced the clutch in my 89 I cracked the bleeder and left the cap off the master. After about 2 min there was a slow drip from the slave line. Then I had a helper pump the clutch pedal 3 times and hold while I cracked the bleeder. Did this three times before I had to add more fluid in the master. Repeated this until no more air came out, about 10-15 times. Link to comment Share on other sites More sharing options...
xjrev10 Posted February 28, 2012 Share Posted February 28, 2012 I had to have someone pump it up and I bled it off, added fluid at the same time. About 10 times. Mine was all brand new parts save for the master. New clutch line and slave. Link to comment Share on other sites More sharing options...
