bucket seats
From a bone-yard MJ that has them. My son and I just got some yesterday for his '89 from a Laredo trim junker that bolted right in. We found out that the base pieces are interchangeable so we swapped driver and passenger sides to put the real good one in the driver's side.
I'd bet that some of the "recycling" pros on this board can tell you about several different kinds of donors.
XJ seats will work if you cut the bench mounts off and use those- but they'll be 3-4" higher, and of course there's modification involved as the brackets are welded and rivited on.
MJ buckets are your only bolt on option that I know of.
