Keep frying electric cooling fan relays!
Every time I put a new relay in the fan runs for about 10 seconds (when engine is hot) and then there are burn marks on two of the relay pins.
If I jumper the relay port (the ones going directly to the fan) the fan runs fine. I checked the connections inside the electrical panel and they seem good.
I have a '91 4.0 HO.
Any other spots to check? Thanks!!
Turns out the aux electric fan had a hairline crack in it, so once I hit 45mph or so the wind would push it into the power steering pulley -- which damaged the fan, cranked up the amps and fried the relays. They really should've put a bigger clearance between the fan and power steering pump.
I had to jumper it to relay to get it home without overheating (I live in Florida) so I hope I didn't damage my ECU :( I got the fan problem fixed by replacing the fan but the Jeep's had a severe loss of power (and shifting problems) since that whole fiasco.
Expensive lesson learned!
