Timmmmmy Posted February 17, 2012 Share Posted February 17, 2012 As stated in previous post... So I have found a 89 4X4 4.0L stock Metric Ton with D44 and the upgraded leaf springs and tires/rims. that I am thinking of buying, He bought it new, it has 230,000KM (143,000Mi) immaculate condition. Original paint with mint decals and clear coat. Interior is great as well, no rust. So I got the factory build specs from the dealer today. I am curious to know if this was a base model or a top of the line. It seems to have loads more features than my 89 Sport truck. I am curious to know if anything really sets this truck apart as the owner is asking premium dollars for it. Any comments are much appreciated. Afterwards I or an admin can move this info into the registration data base. Vin 1J7GJ36LOKL602569 Model year 1989 Family MJ - Comanche Engine ERB - Engine - 4.0L I6 MPI GAS Transmission DDQ - 5-Speed Manual Market C - Canada Body Model JM62 - No description available Build Date 05/02/89 Trim *X1 - Trim style X1 - Cloth Bench Trim Color -Q8 *X1 Trim style X1 - Cloth bench -Q8 Zone 26-Canada-Pacific 126 Canada retail dealer 4HB Special Scheduling condition 2 5AM Largo Tracking APA Monotone paint BAQ 61 AMP Alternator BCX Nickel Metal Hydride Battery BGA Power Front Disc/Rear drum brakes BJA STD Duty frt disc brakes BKP 10X2.5 Rear drum brakes CBA Straight back bench seat CKA Carpets - floor and cargo area CSR Passenger assist handles CUM Mini floor console DBB All manual transmissions DDQ 5-Speed manual transmission DHN Command-Trac part time 4WD system DJH 230MM Front axle DMM 3.07 Rear axle ratio DRK Dana 44/226MM Rear axle EAA All engines EAF All fuel injected engines-Gas ERB Engine - 4.0L I6 MPI Gas GAC Tinted glass windows GBB Tinted wind shield glass GCB Front door tinted glass GEH Fixed door vent glass GFD Rear sliding window GNA Rear view Day/Night mirror GRZ Left Remote Mirror GSZ Right remote control mirror GTZ Manual remote mirrors HCD Heater W/Instrument panel ventilation JAA Instrument panel JAY Instrument cluster W/Tach JBD Bezel - I/Panel cluster - bright JDB 180 KPH Primary speedometer JGB Digital Clock JHA Var Intermittent windshield wipers JJA Cigar Lighter JKB Inst panel mounted hood release K2X Stripe/badge/moulding/color K3W Stripe/badge/moulding/color KKE (Blank on sheet) LAF Key in IGN/Seat belt warning buzzer LAP Shift indicator warning lamp LBC Glove box lamp LCJ Dome/reading lamp B-pillar LMA Halogen headlamps MB1 Black front bumper MBJ Black front bumper MDA Front license plate bracket MFG body color headlamp bezels MHA Black windshield mouldings MMC Rear QTR solid window insert MMG Belt mouldings MMK Body color drip trough moulding NAA Federal emissions NBA Light duty cycle NBK EVAP control system NDA Catalytic converter NF5 Fuel tank - 23gallon NHK Engine block heater PWB Pearl white primary paint - HWB QWB Pearl white secondary paint - HWB RAA All radio equipped RAF AM/FM Cassette radio RCD 4 Speakers SBA Power rack and pinion steering SCE Alcantara wrap steering wheel SFB Front heavy duty shock absorbers SGB Rear heavy duty shock absorbers SUA Tilt steering column TAA All tires TAE Mud & snow tread TBB Full size spare TBM Tire carrier winch TRP 225/70R 19.5 all POS Traction tires WJD 15X7.0 Styled wheels XBS Pick up box XFA -35F Protection anti freeze YAC Build to Canada Mkt specifications YGA Without billable fuel Z01 Rear spring group 1 Z58 Left front spring group 8 Z5B Payload rating - 1800# Z77 Right front spring group 7 Link to comment Share on other sites More sharing options...
Eagle Posted February 17, 2012 Share Posted February 17, 2012 The SporTruck was the base model. It didn't have cloth seat and it didn't have carpets. You are probably looking at a Pioneer. Although, with black bumpers and window trim, it may be a Chief. However, I would not put any faith in what the build sheet reports, because Chrysler recycled a lot of the AMC option codes for other things. I have seen build sheets listing things that were not EVER available on the MJ or XJ, in any year. Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 17, 2012 Share Posted February 17, 2012 :agree: The same applies to the Chryco MJs. My 91 build sheet came back showing a D44, 5-speed, and bucket seats. None of which applied, and I bought it from the original owner. Inaccurate maximus. Link to comment Share on other sites More sharing options...
Timmmmmy Posted February 17, 2012 Author Share Posted February 17, 2012 This is a pioneer. It has the metric ton badge and from what I can tell it has most of these features from when I went to look at it. Now that you mention the recycled codes I will double check a few of the options. The truck seems legit... I really hope I can make a deal on it. Any one know how many metric/ big tons were produced. I imagine it was a pricey upgrade. Link to comment Share on other sites More sharing options...
