Transmission grind fixed by grinding?
I know I need a new clutch kit in the not too distant future, but I was having a lot of issues with reverse gear for a loooonnnnggggg time. It would grind every time i tried to put it into reverse. One day, at work, I had the clutch peddle pressed a little too long, and it lost pressure, so when I tried to put it into reverse, it ground like no tomorrow. But strangely, ever since that happened, it has been a breeze to put it into reverse. It hasn't grinded since. And ideas why this might be? Impending doom for my transmission?
You ground the tips off the synchronizers.
Back in the days of the Detroit muscle cars, a favorite trick among serious drag racers was the remove every other tooth from the synchronizers. It allowed fatser shifts without experiencing the possibility of two teeth hitting face-to-face and causing the shift to "hang." (Not good -- I lost a races due to that, but I had a street car and didn't modify the synchros.)
