jackel18 Posted January 29, 2007 Posted January 29, 2007 was wondering where i could get a front skidplate and oilpan skid? I'm trying to gather up all the materials for my truck so that i can put it together in one shot. i should have a good bunch of pics when i start tearing my MJ apart and putting her back together, in the spring.
pingpong Posted January 29, 2007 Posted January 29, 2007 I guess you can use a skid plate from an XJ, but I have yet to see an engine skid for the MJ. The front steering skid... look in the Junk yards, same with gas tank, and t-case
mjeff87 Posted January 30, 2007 Posted January 30, 2007 Both the front skid and the transfercase skid on mine came from the junkyard. Then again, so did about 75% of the rest of my MJ, too..... :D I just put the TC skid on last weekend. Here's a rundown of it, if you're interested: http://www.comancheclub.com/forums/viewtopic.php?t=3432 Jeff
87manche Posted January 30, 2007 Posted January 30, 2007 front skid is the same as the XJ, but it's pretty much worthless for protecting the steering linkages if you're at anything but stock height. It is however excellent for keeping mud/rocks/water out of the vulnerable alternator, and that's the only reason it's still on my junk.
jackel18 Posted January 30, 2007 Author Posted January 30, 2007 front skid is the same as the XJ, but it's pretty much worthless for protecting the steering linkages if you're at anything but stock height.It is however excellent for keeping mud/rocks/water out of the vulnerable alternator, and that's the only reason it's still on my junk. thats the main reason that i'm looking. i'm only going with a 3" lift so i think it will be ok :thumbsup:
pingpong Posted February 1, 2007 Posted February 1, 2007 To me it is just in the way.... especially if you have to work on something on the lower front end
87manche Posted February 1, 2007 Posted February 1, 2007 To me it is just in the way.... especially if you have to work on something on the lower front end it is a PITA, but I've never seiezed those bolts well, so it comes off with the air ratchet in about 5 min. It's saved my alternator from the nasty nasty ohio mud a few times, so it's worth keeping around if you have to wheel in the slop of the midwest.
