xComancheKidx Posted January 23, 2012 Share Posted January 23, 2012 After redoing the brakes and replacing the clutch mc and line.. i pulled my manche out of the shop and it stalled out and the gas gauge went below E and now she won't start..where should i start my diagnosis? Fuel pump? Link to comment Share on other sites More sharing options...
MJRemi Posted January 23, 2012 Share Posted January 23, 2012 As the gas prices keep going up, theft of gas also goes up. Double check someone didn't syphon your tank while it was at the shop. Link to comment Share on other sites More sharing options...
jimoshel Posted January 23, 2012 Share Posted January 23, 2012 First check the ground behind the left tail light. Then check for power at the tank. Pull the plug and see if you're getting voltage. One wire is for fuel pump. Second wire is for gauge. Then check the fuel pump relay and ballast resister. Also the fuse. Link to comment Share on other sites More sharing options...
xComancheKidx Posted January 24, 2012 Author Share Posted January 24, 2012 bed is off where would this ground be? Link to comment Share on other sites More sharing options...
