78jeepcj Posted January 22, 2012 Share Posted January 22, 2012 I have a 89mj longbed 4x4 5spd, d44 rear 4.5'' lift, i snapped the U straps and ear off the d44 yoke, the driveshaft took some good damage and am curious if there is a junkyard swap from another vehicle vs. having to buy one or have one built. :wrench: I have been searching this site, pirate and crawl, and no luck yet. Link to comment Share on other sites More sharing options...
mvusse Posted January 22, 2012 Share Posted January 22, 2012 There are no other straight swaps that I know off, but there are other trucks using 1310 yokes. My first "custom" drive shaft was out of a 2wd Toyota that I had shortened by my local drivetrain shop for around $100. (Although my current one was custom built out of 3/16 wall DOM tubing for $400). Link to comment Share on other sites More sharing options...
78jeepcj Posted January 22, 2012 Author Share Posted January 22, 2012 yeah I am going to check one junkyard that has a mj. then most likely hack the back off my xj spare DL and take it in with mj DL to have replaced or swapped until I do sye and use a full size bronco front and get lengthend or similar. This is a mild wheeler/duty truck, my cj is the big project if i can ever finish lol. Heck I would weld it if it doesnt mess up the balance which I'm banking on it will, so I will take the chunk out of the wallet and take it in. :dunce: :mad: Link to comment Share on other sites More sharing options...
mvusse Posted January 22, 2012 Share Posted January 22, 2012 More important than being balanced is being perfectly straight and especially being perfectly in phase. Link to comment Share on other sites More sharing options...
78jeepcj Posted January 22, 2012 Author Share Posted January 22, 2012 true. thanks for the input. Link to comment Share on other sites More sharing options...
jimoshel Posted January 22, 2012 Share Posted January 22, 2012 I have always cut and welded my own drive shafts. Never had a problem yet. As mvusse said, just make sure it's straight. I have a 1/2"X8"X8' steel plate I clamp the shaft to using a C clamp on each UJoint making sure it's up tight to the plate. Tack weld it in 3 places. Put in lath, finish welding. Link to comment Share on other sites More sharing options...
