Paul Bruchal Posted January 10, 2012 Share Posted January 10, 2012 Whats the biggest lift I could go using stock CAs with Drop Brackets? This jeep is a "Mall Crawler" until I get Long Arms. I almost have my entire lift together, I am needing the lift parts on my MJ AsAp, because the stock parts are failing right now. Shocks are dead, and I don't have rear breaks "hose has a hole in it". I don't have $700 for Long arm upgrade "yet". Link to comment Share on other sites More sharing options...
mnkyboy Posted January 10, 2012 Share Posted January 10, 2012 The brackets drop your arms about 4" so with a 4" lift your arms would sit about stock angles so I would say you could go as high as 7" if you really wanted to. If you get the brackets I would just get adjustable arms and be done,it will perform better then a cheap long arm upgrade. Link to comment Share on other sites More sharing options...
