airspeed Posted January 2, 2012 Share Posted January 2, 2012 88 Comanche, front axle, D30, CAD. Â I can get the center carrier to move about 1/2", then it feels like it hits a hard stop. It won't come out? Â Is there a internal axle on the right side that needs to come out? I can see a C-clip up in the center carrier on the right side? Link to comment Share on other sites More sharing options...
Geonovast Posted January 2, 2012 Share Posted January 2, 2012 If it's a CAD axle, yes. Link to comment Share on other sites More sharing options...
airspeed Posted January 2, 2012 Author Share Posted January 2, 2012 When all else fails, read the manual... There is an intermediate shaft on the right side held in by the C-clip. Now I'm off to the store for some seals. Link to comment Share on other sites More sharing options...
mvusse Posted January 2, 2012 Share Posted January 2, 2012 If you remove the vacuum shift motor from the axle housing you can access the other end of the shaft through there. Link to comment Share on other sites More sharing options...
airspeed Posted January 2, 2012 Author Share Posted January 2, 2012 As best I can tell someone put the wrong seal in the right side, that explains why it was leaking. The ID of the seal I took out is ~ 1.50", the intermediate shaft measures ~ 1.25". I think a little oil could get by there. The number I see on the seal is NOK UB0441E, not sure if that is a relevant p/n. I think I saw somewhere on here a NAPA P/N 11771? Â I'm off the the main NAPA warehouse in Denver... Link to comment Share on other sites More sharing options...
mvusse Posted January 3, 2012 Share Posted January 3, 2012 in a disconnect axle, there should not be a seal on the right (passenger) side of the differential because oil needs to get to the vacuum disconnect system to lubricate where the two shafts meat as well as the lock collar. There should be a seal on the outboard side of the disconnect. Â NAPA 11771 is what can be used on the passenger side of the differential if you throw out the shift mechanism and two piece shaft to replace it with a single piece shaft. Link to comment Share on other sites More sharing options...
