flyn2er Posted December 30, 2011 Share Posted December 30, 2011 I have the classic brake/ clutch fluid ate up my box. Found a donor xj, same year. Give me some tips and ideas would be great. Can I just cut the box out and redo the box or do I need the whole interior harness? Any help would be great!! Link to comment Share on other sites More sharing options...
Eagle Posted December 30, 2011 Share Posted December 30, 2011 Cut the box out? It should be plug-n-play. Link to comment Share on other sites More sharing options...
KYMJ Posted December 30, 2011 Share Posted December 30, 2011 I didn't want to splice A LOT of wires, so I got the dash harness. You'll have to remove the dash to do it. You'll need a flexible screw driver to remove the top panel of the dash. The rest is not too bad, ordinary tools, but I cannot recall the size of the sockets. I originally was going to replace some of the worst connectors in the box, but chose not to. I have plenty of connectors( I can send you a few) if you choose that method. Link to comment Share on other sites More sharing options...
flyn2er Posted December 30, 2011 Author Share Posted December 30, 2011 Still up in the air on what to do. :cheers: Hats off to anyone who has torn a dash apart. PITA ;) Link to comment Share on other sites More sharing options...
Harley Posted December 30, 2011 Share Posted December 30, 2011 Just remove the small bolt on the harness and unplug the box. Then remove the 4 screws holding the box to the firewall. Link to comment Share on other sites More sharing options...
flyn2er Posted December 31, 2011 Author Share Posted December 31, 2011 Ok... i cut the box out of the xj with plenty of wire to splice if needed. Cleaned out the box and went to work on the manche. 4 hours later new box is in and working. I did need to splice 5-6 wires. Link to comment Share on other sites More sharing options...
