head light knob issues
on my 87 2.5l 2wd mj the head light knob seems to be disconnected behind in the dash because its recedes into the dash when i try to push it in. This is not a major problem because i can reach my hand up from under the dash and hold the box in place to shut off my lights. But i just wanted to know how to get to it, i took apart the dash a little bit and saw its not so easy. I also wanna know how its held in place normally, like is it just 2 screws or what not?
thanks
Yep, I just took the switch out of the donor the other day.
There is a round nut behind the switch knob that you can turn to get it off.
Then there was a button at the bottom of the switch to release the knob/rod.
If you need a switch, I just so happen to have a spare. :D
