Floor rust
i know its been covered a million and 1/2 times, but can't seem to find the info I'm looking for.
on top of the frame rail looks to 2 sheets of metal, can they be cut open to inspect/replace the top?
I'm replacing my floor, and would like to replace/POR as much as possible. I'm not buying a floor pan, I'm just going to use some scrap steel :wrench:
Thank you jamminz.gif looks as if you drilled out spot welds, is that correct?
I used a spot weld cutter. It's like a mini hole saw. I used about 5 of them from harbor freight. I did buy a high dollar kit online, but the HF bit worked the best. Beware, this job is a royal pain and will test your patience.
http://www.harborfreight.com/3-8-eighth ... 95343.html
