Thats about what I spent on my Waggy 44's when I did the swap in my ZJ. Essentially you are just buying the housings as everything else will need to be replaced and updated. Good luck man
RockMJ
Just wondering...if i picked these up, roughly how much $ do ya think it would be before they would be updated and good to go?
2.72 or 3.31 gears so they'll need to be regeared, can you do that yourself? If so it'll be about $600 minimum in parts for each axle. Brackets for the front won't be cheap either, at least $400 plus installation.
Lot of money to get them ready for an MJ.
I spent a few thousand on mine but I also beefed them up a great deal. Custom chromoly shafts, TnT trusses, etc. Bare minimum if you did all the work yourself would be in the 1000-1500 range I would say
RockMJ
I'm in a pretty small town on the east coast called Jensen Beach, Its right in between Stuart and Port Saint Lucie.... If that doesnt ring a bell its also 2 hours south of Orlando, and 2 hours North of Miami.
Good to know theres someone on here thats relatively close to me!
