tbrand Posted December 3, 2011 Share Posted December 3, 2011 So, my truck was typically idling around ~1250 rpm, and I finally had some free time to fiddle with it. I pulled the throttle body and cleaned it out thoroughly, as it was a mess. I reassembled everything the way it was and... now my idle is up around 1500 rpm. This is, of course, once I've gotten the truck warmed up. Immediately after startup, it idled around 1000 rpm both before and after cleaning. Ideas? '89 Renix 4.0 5-speed. Link to comment Share on other sites More sharing options...
RockMJ Posted December 3, 2011 Share Posted December 3, 2011 Check for vacuum leaks to and from the intake manifold. The lines might be dry rotted and causing some leaking RockMJ Link to comment Share on other sites More sharing options...
cruiser54 Posted December 4, 2011 Share Posted December 4, 2011 TPS failure or adjustment. I have a write up on the TPS but you need a voltmeter. Got one? Link to comment Share on other sites More sharing options...
tbrand Posted December 4, 2011 Author Share Posted December 4, 2011 I had a multimeter, but it has disappeared. Probably in a box somewhere, but 8 months after moving, there are still boxes we haven't touched. I may just go pick up another one at HF or something. They're not too spendy. I'll double-check the vacuum lines again. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 4, 2011 Share Posted December 4, 2011 For when you find your meter: RENIX TPS ADJUSTMENT Before attempting to adjust your TPS be sure the throttle body has been recently cleaned. It's especially important that the edges of the throttle butterfly are free of any carbon build-up. IMPORTANT NOTE: Using the positive (red) lead of your ohmmeter, probe the B terminal of the flat 3 wire connector of the TPS . The letters are embossed on the connector itself. Touch the black lead of your meter to the negative battery post. If you see more than 1 ohm of resistance some modifications to the sensor ground harness will be necessary. The harness repair must be performed before proceeding. I can provide an instruction sheet for that if needed. MANUAL TRANSMISSION: RENIX manual transmission equipped XJs have a three-wire TPS mounted on the throttle body. This manual transmission vehicle TPS provides data input to the ECU. The manual transmission TPS has three wires in the connector and they're clearly embossed with the letters A,B, and C. Wire "A" is positive. Wire "B" is ground. Key ON, measure voltage from "A" positive to "B" ground by back-probing the connectors.. Note the voltage reading--this is your REFERENCE voltage. Key ON, back-probe the connector at wires "B" and "C". Measure the voltage. This is your OUTPUT voltage. Your OUTPUT voltage needs to be seventeen percent of your REFERENCE voltage. For example: 4.82 volts X .17=.82 volts. Adjust the TPS until you have achieved this percentage. If you can't achieve the correct output voltage replace the TPS and start over. AUTOMATIC TRANSMISSION: RENIX automatic transmission equipped XJs have a TPS with two connectors. There is a flat three- wire connector, same as the manual transmission vehicles have, and it is tested the same as the manual transmission equipped vehicles--FOR ENGINE MANAGEMENT RELATED ISSUES. However, the automatic TPS also has a square four-wire connector clearly embossed with the letters A,B,C, and D. It only uses three wires and provides information to the Transmission Control Module. Key ON, measure voltage between "A" positive and "D" ground. Note the voltage. This is your REFERENCE voltage. Back-probe the connector at wires "B" and "D". Measure the voltage. This is your OUTPUT voltage. Your OUTPUT voltage needs to be eighty-three percent of your REFERENCE voltage. For example 4.8 volts X .83=3.98 volts. Adjust the TPS until you have achieved this percentage. If you can't, replace the TPS and start over. So, if you have an automatic equipped XJ your TPS has two sides--one side feeds the ECU, and the other side feeds the TCU. If you have TRANSMISSION issues check the four-wire connector side of the TPS. If you have ENGINE issues check the three-wire connector side of the TPS. For those with a MANUAL TRANSMISSION--the TPS for the manual transmission XJs is stupid expensive. You can substitute the automatic transmission TPS which is reasonably priced. Revised 11-28-2001 Link to comment Share on other sites More sharing options...
