randimal Posted January 17, 2007 Share Posted January 17, 2007 I'm putting the stock radio connector thingy back in. The last guy didn't buy an adapter for his radio but instead hacked everything. AM is not working and I think shorts might be draining the battery, so I'm putting an old harness back in. However, the wires are slightly different on my cherokee. Whats this blue wire with a plug? I'm guessing its ground, but on the cherokee its a black wire with a standard slide-on terminal connector so I want to make sure. Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 18, 2007 Share Posted January 18, 2007 Here's the pinouts for 91+ models, but the earlier models are most likely the same. Link to comment Share on other sites More sharing options...
jbhill Posted January 18, 2007 Share Posted January 18, 2007 looks like he wast o lazy to take the radio bezel off and hacked i tup to, u need another one i got 3 haha. Link to comment Share on other sites More sharing options...
jage Posted January 18, 2007 Share Posted January 18, 2007 Isn't solid blue usually the power antenna? Link to comment Share on other sites More sharing options...
randimal Posted January 18, 2007 Author Share Posted January 18, 2007 You could be right about the power antenna. The one wire from the harness that I didn't connect was marked as power antenna on the diagram on my radio. But it came straight from the connector, no separate plug and it was grey. But my radio was from a Laredo. Could be that one of the base model radios had a separate plug for power antenna. Doesn't matter to me, though. Don't have a power antenna on the MJ, and I swapped the XJ one to fixed long ago. Anyhow, I got everything hooked up and it works great. Thanks a bunch. Also, I pulled the bezel off my XJ. Also threw in a clock, fog light switch and some other goodies. Link to comment Share on other sites More sharing options...
87manche Posted January 18, 2007 Share Posted January 18, 2007 see here, it was accurate for my 87, I had the same mess you do. http://snowboard247.blogspot.com/ Link to comment Share on other sites More sharing options...
