jons87mj Posted November 9, 2011 Share Posted November 9, 2011 my UPPER control arm bushings at the axle needed replacing but i can't get the old ones removed :mad: So my question is how do you remove theis any help would be helpful thanks jon Link to comment Share on other sites More sharing options...
Motion Offroad Posted November 9, 2011 Share Posted November 9, 2011 Drill holes in the rubber until most of it's gone. Than crush the metal sleeve with a hammer and push it out. Option 2 involves a torch, but stinks really bad... Link to comment Share on other sites More sharing options...
jimoshel Posted November 9, 2011 Share Posted November 9, 2011 Option 2 involves a torch, but stinks really bad... YEP! But it works. :yes: Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 10, 2011 Share Posted November 10, 2011 I got some parts from a salvage store and made a press (threaded rod, long nuts, a plumbing reducer that the ID was big enough to press out the bushing, and assorted flat washers, all for about $5). It worked great and didn't stink and didn't need a BFH. It also didn't compress the bushing ears. Link to comment Share on other sites More sharing options...
