drcomanche Posted October 17, 2011 Share Posted October 17, 2011 Today, I installed my speedometer gear, which is a good step towards being able to tell how fast I'm going, but I'm still missing the wire that connects to that. Does anybody know where I can get one? Or, perhaps more importantly, does anybody know where it connects to? I looked at my guages, and it's an all electrical housing. I just don't know where to be looking for a connector, and I have a LOT of disconnected/hacked wires. Link to comment Share on other sites More sharing options...
Eagle Posted October 17, 2011 Share Posted October 17, 2011 You have an all-electric gauge cluster in an '88 MJ? Was the entire '94 wiring harness swapped in? If not, you have a problem because the '88 originally had a mechanical speedometer with a conventional speedo cable. Link to comment Share on other sites More sharing options...
drcomanche Posted October 17, 2011 Author Share Posted October 17, 2011 It was converted to a later unit. The entire engine and drivetrain is from a 94 cherokee. Some of the wiring is spliced, but the most of it is the 94. Link to comment Share on other sites More sharing options...
Eagle Posted October 19, 2011 Share Posted October 19, 2011 It was converted to a later unit. The entire engine and drivetrain is from a 94 cherokee. Some of the wiring is spliced, but the most of it is the 94. Unfortunately, then you're on your own because we can't tell from wherever we sit if the speedo wire was even moved over to your truck. You need to find an XJ or MJ from about the same year, crawl underneath, and find out what color wire you're looking for and where it's supposed to go into the chassis harness. Link to comment Share on other sites More sharing options...
drcomanche Posted October 19, 2011 Author Share Posted October 19, 2011 Well, that's unfortunate. But on the bright side, there are no lack of Cherokees around. Link to comment Share on other sites More sharing options...
