Pilot bearing
Trying to figure out the size of my pilot bearing. Not sure of the diameter on the input shaft. Do I have to guess here or is there a common size? Rockauto lists like 5 different ones.
Its an 86 Manual AX5 2WD. I am replacing my throwout bearing and was told to get one of these too. It is my DD and I don't want to pull it to get a mic on it then order it and put the trans on only to pull it again.
Yes there is a cross-reference for a few of them with that P/N. But the sizes don't match up.
These 2 are under Pilot Bearing.
-Inside Dia: 0.673"; Outside Dia.: 1.055"; Length: .626"
DORMAN
Alternate/OEM Part Number(s): 14675, 3222723, 83500786, J3222723
-Width=.747"; Outside diameter=.8310"; Inside diameter=.5910IN
SKF
Alternate/OEM Part Number(s): 476574, 83500786
This is under Pilot Bushing
-Bushing; Bore=0.592", Outer Diameter=0.829", Width=0.755"
NATIONAL Warranty Information
12 months
