pug Posted September 26, 2011 Share Posted September 26, 2011 Driving home friday truck started cutting out when letting of the gas. Like its not getting gas i push down on gas pedal takes off like nothing wrong. Thought it might be part of the distributor problem.Replaced plugs,cap,rotor,distributor and cps. 2.5, ax5,231. Any ideas thanks Link to comment Share on other sites More sharing options...
nitroxsteve Posted September 26, 2011 Share Posted September 26, 2011 Driving home friday truck started cutting out when letting of the gas. Like its not getting gas i push down on gas pedal takes off like nothing wrong. Thought it might be part of the distributor problem.Replaced plugs,cap,rotor,distributor and cps. 2.5, ax5,231. Any ideas thanks I put a reply in you distributor thread explaining what I found on my truck and this was also one of the issues I had, It would only pull at WOT and miss at part throttle. The timing was off and at WOT throttle it would smooth out. My truck is 4.0 not 2.5 by the way. hope this helps. Link to comment Share on other sites More sharing options...
tbrand Posted September 26, 2011 Share Posted September 26, 2011 On my 4.0, replacing a bad O2 sensor fixed several drivability issues. If your timing is good, you might check that. Link to comment Share on other sites More sharing options...
pug Posted September 26, 2011 Author Share Posted September 26, 2011 Wouldnt it idel rough if the timing was off. Unpluged o2 and drove couple miles same result. Link to comment Share on other sites More sharing options...
nitroxsteve Posted September 26, 2011 Share Posted September 26, 2011 Wouldnt it idel rough if the timing was off. Unpluged o2 and drove couple miles same result. My truck would idle fine it was when under load and the disributor would try to advance the timeing it would miss. WOT it also ran well. Link to comment Share on other sites More sharing options...
pug Posted September 26, 2011 Author Share Posted September 26, 2011 Is there any other way to check timing besides tdc. Link to comment Share on other sites More sharing options...
jcComanche86lb Posted September 26, 2011 Share Posted September 26, 2011 Should be able to use a timing light to check it. I would check for vacuum leaks also. Link to comment Share on other sites More sharing options...
