MJRemi Posted September 19, 2011 Share Posted September 19, 2011 I may end up buying the 92 I posted in the CL etc. section. It's 4.0 2wd auto on the column. The tranny will need attention pretty soon. Will a (89 XJ) floor shift auto 2wd bolt in or would I be better off having the 92's rebuilt. I can get the 89 AW4 for $50. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted September 19, 2011 Share Posted September 19, 2011 92 if i am not mistaken will have a electronic speed sending unit and the 89 will have the mechanical speedometer.. as far as the shifter goes you should be able to swap it over Link to comment Share on other sites More sharing options...
MJRemi Posted September 19, 2011 Author Share Posted September 19, 2011 I should add that I would prefer the column shift option. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted September 19, 2011 Share Posted September 19, 2011 you should be able to keep the shifter no matter what you do, if you choose to swap transmissions you need to make sure you have the proper speed sending unit for your Jeep Link to comment Share on other sites More sharing options...
